Only some lamps on the display board illuminate - 1999 M1088A1
AlluvianHaul
Colorado
A little while ago, the line wire to the low-air alarm came into contact with the display board burning out several of the circuits. The board was repaired, but some lights still do not illuminate. Any ideas?
The lights that work when I press the Lamp Test switch are:
  • Left Turn Signal
  • High Beam
  • Engine Brake
  • CTIS Overspeed
  • Chemical Detect
  • ABS
  • Dump Body Up
The ABS lights may be dimmer than the rest.
