ORD brake hose, m1028, different fittings?
Twigiestdrip
FL
So I recently purchased the extended braided steel brake lines from ORD, without really giving much thought to their fitment as I've heard them recommended here. (Obviously dumb in retrospect).
Anyway, after they arrived and I took a look at the lines I looked at the truck and realized that the front brake hoses end in a steel line with a square end that connects to the caliper. however, the ORD lines end in a typical looking round end that the banjo bolt goes through.
Obviously I haven't checked yet, but does anyone know if I would be able to still just swap them out and that other fitting would fit properly?
Big thanks.
joshuak
214
Slower shore, DE
They work for me.
I'd suggest using the new banjo bolt and copper washers they supply and also moving the wheels lock to lock before final torque to make sure there are no pinch points.
