EveOfDestructionDeuce
- 0
- 0
- Dortmund/Germany
Please does anyone have a pic from the original long shaft hand crank (with winch) to start the engine manually....could not find anything at the web.I build the hand crank by myself and the bracket with hole for the front bumber which is often missing...The hand crank was std.equipment for every CCKW, wondering staying not in the manual at tool and assesory list.Where was it stored at the truck and was they often used, winter time?Not a good construction that you must turn of the winch cable completely to use the hand crank
