Thanks for the suspension advice. I will get the truck out of hibernation this weekend and go to a suspension shop to give me some ideas.I have a simple idea for an air ride up front. I'd get a second pair of shackles (at the rear of the spring), double them up like chain links, and use an off the shelf airbag between the frame and the spring plate above the axle, in place of the rubber cone bumper. When the airbag bottoms out, youll still have the stock spring travel. The rig I would build would use only two axles, and I'd use a set of front springs for the rear axle, so front and rear air ride on the cheap.
I hope you dont use any RV particle board cabinets or anything else from commercial RVs. Those would get shaken to bits, probably even with the air ride, and theyre heavy as can be. Your whole project should be on Jenny Craig what with the steel box as a starting point. I thought I'd look for a commercial truck box like a Morgan body. All aluminum, and if you look hard enough, maybe even cheaper than a shipping container. Easier to insulate, cut holes for windows, etc. Even get a price on a new one spec'd out how youd like and see how much it would be. Either way, awesome project. Hope I can start one similar as typical RVs are crap.
For the box,?I prefer build it myself. I will be able to optimize every inch in space. Important because it’s a retirement project and you always need more space
![](http://emoji.tapatalk-cdn.com/emoji1787.png)
Tks again
JC
Envoyé de mon iPhone en utilisant Tapatalk
