Harleyd315
- 5
- 18
- Denville,New Jersey
I have a 002 that runs great but has a high voltage condition. Starting the unit the voltage goes up to 140/260. I tried adjusting with the rheostat but even turned all the way down it still stays high. I have checked with my other test meters and the voltage reading on the set are correct 140/260 output. A couple of times I was able to stop the gen and restart it and had good voltage readings. I looked in the TM and did try to adjust R16 but it made no difference. This unit appears to have been totally rebuilt and all the components/gauges in the control box appear new including the volt regulator. Can the rheostat be the problem? And if so how to test. Or am I looking more towards the AC voltage regulator. Any help would be appreciated, Thanks
