p/n for turn signal switch
jimm1009
71
Louisville, KY
Has anyone located a MS part number for the connector for turn signal switch located on the truck side of the harness?
I need to replace the cannon plug that attaches to the turn signal switch.
Thanks, Jim
jimm1009
jimm1009@yahoo.com
Warthog
237
OKC, OK
Thanks, Jim
jimm1009
jimm1009@yahoo.com
Contact Barrman. His buddy Allen is a salesman for electrical connectors. He should be able to get you a new one.
You may also want to look at replacing it with a connector from a parts truck.
jimm1009
71
Louisville, KY
I found the connector p/n in the 361 series TM.
The p/n is MS3456W18-8S.
I'm not usre what finish the W is but there could be other finishes
used if the W version is not available.
Regards,
jimm1009
