P/S pump install
CanadianAR
95
Ontario, Canada
I am working on a guys hmmwv for him. He local and couldn’t find a shop to do it. I have been a diesel tech for 20 years.
His alt bracket had broken off, and he pulled it out on his own with the steering attached. But I reinstalled it without the pump so I could ensure proper mating and torque.
it’s a 195000 A2. Everything I’ve read it should just come out/go in.
I’m getting hung up on the return spigots on the back of the reservoir.
M
Any ideas.
FlameRed
512
Florida
I am a novice myself, but I would ask if you were given the correct (military) pump. I understand the civi pumps are different than the military ones. But maybe that is only on the internals.
When I did mine, I bolted the bracket to the pump first and then the assembly to the engine. Then I installed the generator bracket, and the generator last.
Maybe just remove the bracket and try to mate it to the pump first and then install the whole assembly.
CanadianAR
95
Ontario, Canada
It’s a military pump.
I guess I’m taking two bolts out of the bracket to pivot it. Man, they went so far forward with the hmmwv for its time, but Alt and P/S dept dropped the ball,
Mogman
9,511
Papalote, TX
Man, that truck just missed the PS upgrade to a remote reservoir at 196901 :)
