Fluflufpv
- 9
- 3
- Washington
Hello all! I'm working on a non military vehicle (1983 dodge ramcharger) but it seems users on this site use a lot of Gillespie paint so I thought I'd go here. Anyway, I have two major questions:
1) Can Gillespie paint be sprayed directly over epoxy primer? I'm not looking for color accuracy so if the tint of the final spray is off it's not a big deal, just more concerned about adhesion. Additionally, if you can use epoxy primer, should the Gillespie be sprayed within the recoat time of the primer or wait for it to cure completely?
2) Assuming I use hardener ( I don't mind if it's shinier then without it), about how long can I expect before it starts to fade or chalk up badly adding it lives most it's life in the elements (that being said I'm in Washington so sun wise it's not as bad as other places)? If you have pictures of like 5 or 10 years or something that would be great! I've been reading anywhere from 1 to 8 or more years so would really like a few pictures of what an older Gillespie job looks like fade and chalking wise.
If any of you can help out it would be great appreciated!
