Paint lot Numbers Different
rboltz
Hershey, PA
Got caught again in Gilispie 24087 lot numbers in a case. Shame on me as I got the same thing a few years ago with a case of gallons. You would think a 4 gallon case would be the same lot. I had to open a new can today to paint more blasted parts from Friday. What a difference in color and gloss from the last can. I looked and different lot numbers in the same case. When I put the truck together, I'll have to scuff and paint the whole truck so it matches! Beware if you buy cases!!!
SteveKuhn
Hasbrouck Heights NJ
It's not so common for run numbers to differ by much any more, especially when they've cured. SRJeeper and I were talking about that with touch ups. At first, there's often a difference. After a couple of months, the difference often fades. My dad was an old time painter who taught me a few things about run numbers when you can't get them the same:
- Check numbers before you start and plan.
- Change in a shadow corner and don't paint parallel surfaces with different runs. (e.g. perhaps do the tailgate & rear or a whole side with the same numbers.
- Use the odd numbers as 1st coat if you're doing 2 or more.
- Mix the cans together to get them all the same.
Mebbe helpful, mebbe not.
Steve
nattieleather
138
Cleveland, OH
Actually most trucks were given a finial coat at the factory for that reason and a few more. Part of it was because some parts came prepainted from other vendors. Also any bolts that were put in had to get touched up. So the truck would get a final shot before rolling off the line. (or at least that is how they were done in WWII not sure if they did that in post war plants.) It will be good to give it a finial coat anyway.
rboltz
Hershey, PA
Gloss
The problem is not as much color as gloss. I've painted lots of 24087 over the years and NEVER saw gloss like the can I just used. It shines like a nice new laquer car. Not sure what is going on but it stopped my painting until I get a new batch or, I may shoot 1 coat with this lot and then recoat with a new lot. I just hate the idea of scuffing and masking the entire truck after assembly.
M-37Bruce
59
Midlothian, VA
Additives
Couldn't you add a de-glossing agent to the Gillespie you have, they are a few tricks to do this.
I don't mind the gloss, the finish is actually a harder finish, eventually the gloss will fade to what you one want.
