Paint Use?
Tin Medic
FT Carson, CO
Picked up a can today and took it to Lowes to have them shake it. The paint is definately darker than the shade MWMules referenced above. There is still some clumping in the bottom of the can but I believe it is due to needing to be shaken longer. If you look at the edge of the can you can see a darker shade than the can lid, that is the actual color, the flash made the lid color look lighter.
Jeepsinker
456
Dry Creek, Louisiana
May be worth getting a cheap airbrush from harbor freight if you don't have one already and then spraying a small metal test panel, then let it cure in the sun just to be sure of color. After complete shaking that is. That little bit of clumped material on the bottom could make a large difference in final color shade, but it also may not....
Either way someone will want it to do a restoration eventually.
