Parasitic draw on batteries
Mogman
9,610
Papalote, TX
No accessories added. I do have a bad light switch that I unplugged. There is still some draw on the batteries though.
Simple enough to tell, unplug the engine side then re-connect the batteries and check again, if the parasitic draw is gone then plug that connector back in and then remove the inside connector, if it has parasitic draw then it is likely the box, if it goes away then it is something connected to the inside connector.
86humv
504
Texas
If the truck has the 4 spd. trans.....
The relay in the panel behind batteries do fail on with ign. switch off.
If trans light works, and if relay fails on....light will be on with ign. switch off.
