ken mcculloch
- 0
- 0
- Fremont, CA
I was going to adjust my parking brake yesterday & ran into a snag. It appears that I have run out of adjustment on both the adjustment bolt & the “J” bolt with the springs. Upon further investigation, it seems that basically the top 1/3 of the brake lining is not even there so that’s probably why I can’t make the adjustment… not enough lining. Looks like I will be buying a new lining & band.
In addition, while I was there I was surprised at what seemed like a fair amount of TC fluid splattered all over the springs & adjustment bolts, as well as the underside of the body. THEN, I noticed that the speedo cable was not attached to the TC. (I knew it was not hooked up to the speedo but …) QUESTION… if the cable is not in the TC, is the TC open to the elements & free to throw fluid about? I assume the hole that the cable goes into is open to the inside of the TC???
Thanks, Ken
Thanks, Ken
