spectre6000
- 3
- 0
- Broomfield, CO
So this just happened...
I was trying to remove the coolant temp sensor from the back of the block while I had easy access to it, and no amount of anything would get it loose. I nearly broke my 7/8" line wrench! I ended up having to take the whole flange off, and even putting it in a bench vise yielded no positive results. I eventually realized what I was attempting to remove was an adapter for the actual sensor, and got the sensor itself out, but now the adapter is completely trashed, will not budge (loose or tight), and I'm almost convinced the flange itself is probably a little warped now. I need to find another one, but I'm not really sure what to call it and can't find a part number. Help appreciated. Thanks.
