Part #s for lug nuts/thimbles
TruckGuy
24
Belmont, NC
Yep, I did a forum search.... Found a few threads from around '09. The NAPA part #s came up with zip on the NAPA site. I can find these on Epay, just trying to compare price. I don't have the rear nuts/thimbles to to take off and match at the store (rears are singled.. going back to duals)
Anyone know current part #s for local stores? (NAPA, Advanced, O'Reilly etc.)
Looking for rear lug nuts/thimbles and front lug nuts.
1,176
You should have just continued one of the previous threads, not start a new one.
You need truck parts, I doubt Advance and Oreilly will have them.
Napa numbers don't usually change and if they do, they usually cross reference on their site.
swbradley1
Modertator
1,695
Dayton, OH
I have lots of new ones I got at the Marengo show two years ago. I wonder if the number is in the manual?
TruckGuy
24
Belmont, NC
jcappeljr - I'll keep that in mind, but I'm really looking for new parts.
swbradley1 - You looking to sell any? I'm looking for a full set of nuts/thimbles for both rear axles.
Anyone got part #s?
m16ty
211
Dickson,TN
Just go to NAPA and tell them you need nuts and/or thimbles for bud wheels. I'm not saying there aren't some out there but every truck (civilian or military) I've ever seen with bud wheels used the same nut and thimble.
Just remember to get left handed ones for the drivers side.
1,176
Part numbers should be in the parts TM.
I doubt the part numbers have changed since 09, so the old threads should still be good.
porkysplace
1,487
mid- michigan
The napa part numbers that grimpyrobb posted a link to in post# 7 of this thread deuce wheel stud are not showing up in a napa search , but post #1 has the stud description from the TM so any good parts store should be able to match them with that .
TruckGuy
24
Belmont, NC
I believe these are the current NAPA #s. I'm going to pick up some of these, so I'll confirm the #s when I have them in hand.
Rear Duals...
Inner - Left Hand - TWD WA2001
Inner - Right Hand - TWD WA2000
Outer - Left Hand - TWD WA2011
Outer - Right Hand - TWD WA2010
Front/Rear Singles...
Left Hand - TWD WA2007
Right Hand - TWD WA2006
Studs...
Left Hand - TWD WA1211
Right Hand - TWD WA1210
I'll let you guys know
juanprado
2,886
Metairie/La (N'awlins)
I am not sure those are correct. Twd is a special order for napa. When I was with them studs and nuts were balkamp bk line code that were store stocked items. Part numbers started with 620-xxxx
TruckGuy
24
Belmont, NC
juanprado - That could be. Some of the #s I got from older threads were BK 620-xxxx. Tried looking those up and got zip. But the site "Interchanged" those to the TWD #s. From there I just got the #s for Left and Right. I'll ask about the bk line when I'm at the store. At least these #s get me started.
juanprado
2,886
I could be wrong as things change. I am no longer an indentured servant to them :)
Any counterman with hd exp will just go grab them out of the box as they fit anything budd. Studs will require to be looked up.
