majoseM37
- 0
- 0
- Hayward, CA
I have a 1953 M37 that has been partially converted to a 12 volt system. It has a 12 volt alternator, coil and distributor. The starter went out, after removing it I discovered that it is a 6 volt. The starter solenoid is fender well mounted, the ignition is a push button on the dash. I want to replace the 6 volt starter with a 12 volt. All of the lighting has been converted to 12 volt as well. I have contacted a couple of vendors online but they don't have a starter that will work for me. I found this 12 volt starter on Ebay advertised for the 12 volt conversion. [FONT="]It is a modified late model Nippon Denso Offset Gear Reduction Starter [/FONT][FONT="]MCZ-4002UT[/FONT] Anyone advice would be greatly appreciated.
