Recon1172
- 3
- 0
- Snellville, Ga
Hey guys, I recently bought a 95 6.2 liter Humvee. I'm planning on doing a brake job when the weather warms. I've been doing some research and can't find the answer to the following questions...
1. In the sticky about LEO/FD HMMWV, it says that the front calipers from a 82 AMC Eagle will fit the Humvee. The Humvee uses the same brake gear on the front and back so this would work all around then right?
2. If the calipers fit....does that mean the rotors and pads fit and are a good choice as well? Something tells me that maybe the rotors or pads might be beefier on the Humvee?
3. I have the parts manual and have found the parts on Mac Motors, but where do you guys source your brake parts? Can it be done locally using civilian parts?
Thanks in advance
-Recon
Thanks in advance
-Recon
