Been thinking about the same thing for my M813, which started life with the Air Force in Georgia...so, no heat. Found that the drivers side tool box will fit thisNow that it is colder I am thinking about adding cab heat to my m51a2.
I'm running a 24V to 12V 40Amp Step down off a 24V dual battery bank switch to a 12V fuse block. The only thing I have on it are LED reversing lights and a beeper.If you do go for a 12V unit, don't be tempted to draw the power from a tap between the batteries.
yeah, a bus heater would be excellent, or a decent box heater mounted underneath the pass seat, such as the rear-seat heaters one would find in some higher-end cars like chrysler's and lincoln's in the 70s-80s, the ones that were mounted up high under the rear deck in the trunk, their own self-contained unit .. I had put one in between the seats of an old ragtop jeep in the 80s and it was great.. Being that the poster is in FL/GA , the GI heater should be satisfactory.. All I know is back in the 70s-80s the GI heaters, what very few trucks had them in the units I was in , were worthless unless engine was up to temp, wind wasn't blowing, and you were sitting still at least 10 ten minutes.. Only then, if the door windows weren't too leaky, you wouldn't see your breath anymore and maybe the windshields would start to defrost by themselves.. But in less than a minute of moving down the road the heat would be pretty much gone .. This "wonderful" performance was in temps below 28F .. I have 1950s commercial trucks here with larger/better heater cores than the GI ones , sad to sayIf you dont need room for a passenger, a rear school bus heater is an easy addition that will provide all the heat you need.
Yep, thats how I had my first gen Bronco set up with a school bus heater in the 80’s as well! Even with the extra large, automatic beer can disposal holes in each of the floor boards, I didn’t need to put the junk hardtop on until January….. I had put one in between the seats of an old jeep in the 80s and it was great..
