Parts
m139h2otruck
NH
We bought AR8S plugs from Memphis, cheap, that fit. Have Champion plugs in it now, that are hotter than the spec plug. No problems to date. In the back of the Champion master catalog, is a listing for the shielded plugs that shows the interchange and the heat ranges. The plugs for the R-6602 are a 13 mm x 3/8" reach, with gasket.
m139h2otruck
NH
We used a WIX filter base and bolted it in place of the existing unit. Tubing matched right up with the correct fittings. Lets us use spin on fuel filters, with anything from 5 micron to 30 micron with or without water drains.
