Passenger side door will not open
cucvrus
10,427
Jonestown Pennsylvania
I will assume you have it unlocked. Try unlocking it with the key and use a bit of force. Does it appear that the linkage is still hooked up on the interior remote handle. Do you feel any resistance? Push in on the door while trying o open it. Just a few ideas. Good Luck. You may end up wasting the interior door panel.
sneekyeye
134
ALABAMA
Roll down the window and look down inside the door and see if there's anything jamming up the mechanism or any of the bars in there. If you're lucky it'll be an easy fix. You might try spraying lube in the lock if everything looks ok and maybe you'll get lucky.
nyoffroad
687
Rochester NY
The inside and outside handles use different linkages and clips so even if one is broken the other should release the door. Make sure its unlocking( Like cucvrus said) Some penetrating oil wouldn't hurt and make sure that the linkages are moving. IIRC the lock (not the lock cylinder) can get jammed from lack of lube and then it appears to be unlocked but it's not and then jams up the opening part of the latch.
Tanaga
Palmer, AK
I’ve sprayed liberal amounts of PB Blaster in all the parts I can reach. I’ve taken the key and locked and unlocked the door several times. I’ve gone inside and tried opening the door with some force. I’ve tried opening the door while lifting and also pushing and pulling on the handle. No luck so far.
Matt5
Banned
214
Had this happen to me... can't remember what I did in the end... it was something so stupid...
Drock
12
Eatonton GA
Okay lets try this... It sounds like the lock linkage has come off. So with the widow mostly up so you don't scratch it. Use a coat hanger to fiddle with the latch mechanism it's self. Close your eye's and use your minds eye (or the Force) :carnac:to envision the 2 lock rods and the direction they move. These rods operate small levers on the latch. If you can move the right one BINGO your in! Also, maybe take off the drivers door panel so you can see & feel how they operate.:beer:
olly69
Cuba, New York
My door doesn't open from outside, just from the inside (passenger side). But I have opened it from the outside with a flat head screw driver, carefully. I wedged it down from the top, pushing the plunger latch open.
cucvrus
10,427
It is a very crude set up. Take it apart and fix it. A few rods and levers. If you or anybody need any of the rods or levers speak up. I discovered a cache of CUCV door parts. Enough to last 2 lifetimes. Some with nice doors still attached to them.
nyoffroad
687
Rochester NY
:lol::funny: I'm sure you do!
Years ago my then teenage son came home with an Chevy truck that was everything he didn't want. It was a 6 cyl. 3spd manual and a rot box. I replaced everthing including engine, transmission, cab bed and front sheet metal, all from parts I had in the garage. And yet some how I don't think you would be impressed by my stash!
