dabtl
- 7
- 38
- Denton, Texas
I have been working on fixing the steering gear. What a task.
No one has adequately covered what is involved here.
First, were I doing it over, I would recommend trying to remove the most upper rear bolt from the steering gear cover. If you cannot do that then an experience awaits. Everything hinges on that bolt.
If that bolt is too close to the engine to come out, get a two ton hoist. Remove the nuts on the motor mounts, four, and lift the front of the engine about 1/2 inch. All else falls into line.
I got new bushings and steering column bearings from Memphis and installed them per directions.
Do not attempt to put the steering column into the box all at once. Put the bearings on the bottom end of the steering worm and insert them into place. Then put the upper bearings into position. Finally insert the steering column and tighten.
Following these simple instructions will save you hours of frustration and cuts on your hands.
Trust me when I tell you that patience and thought will cure a lot of frustration.
