Permanent removal of engine fan? Driving without fan
res0wc18
Everett, Wa
So as I'm rebuilding the injection pump etc etc I'm wondering..... is there a real reason to have the mechanical clutch on in mild pacific northwest weather? Don't these things have huge radiators anyways?
Long story short considering leaving it off. Anyone done the same? Any reason why i shouldn't?
My 4bt and 6bt cummins powered ford neither have fans. Never any overheat issues. I understand its a v8 and not an inline and that makes a big difference in heat shedding.
1,172
What could you possibly gain?
Mine will get hot towing on a couple mile long incline.
1,172
It has a clutch, is your bad?
Kalashnikov
NH
If you idle for a while in the summer on a hot day I think it could be an issue. My 7.3 in my F350 has a bad fan clutch and won't engage at idle. It has started to overheat if it idles for 15 or so mins on a hot summer day. Or a lot of low RPM low speed crawling.
