Pic request - rear identification lights - 3 red lights
sed6
OKC, OK
I'm considering adding what the DOT calls rear identification lights, the three reds in a row generally required on vehicles wider than 80" to the rear of my M925. I've seen a few pics here, mostly from members in tedious inspection states, but a search hasn't turned any up. I'm trying to get some ideas as to what type of light I want to use and where to locate them. Pics or links to pics would be much appreciated.
Thanks!
Skullmaster
Isanti, Minnesota
Here is mine, I used little led markers that I got from northern tool, I have over 30 of them on my truck. Go for about $2.99. They are 12v, i hooked mine into a converter wired into the running lights
sed6
OKC, OK
Wowzers, nice! I knew I also wanted to add some side marker lights, and yours up top look great. Anyone else please?
FullSpecial
108
Denton TX
Helps to have a good friend that's a welder/fabricator and doesn't mind working on something different.
For a few dollars I'm sure they would. Draw out what you want a little small with a Sharpie and grind out to your true dimensions.
sed6
OKC, OK
Well it took many months but I finally got back to this project. I decided for now not to cut into the truck and instead add them underneath the bed. I also added some reflective tape to help with visibility, specifically when parked on the street overnight.
