chuck-10
- 0
- 0
- shippensburg,PA
If any one can tell me what all the switches do inside that would help me out.
That is a nice looking 404! It's not a Swiss version, might be Belgium, do you know? Are those fold down bed sides? Do you have a large tow chain with master ring across between the rear frame ends?If any one can tell me what all the switches do inside that would help me out.
The big chain and ring on the rear confirms you have a Belgium truck. Both my trucks are German and 3rd switch is for a work light, 4th switch for electric transfer switch for fuel (for radio box heater), but that is probably not what your 3rd and 4th switches do.That clears up the mystery on the 3rd switch,just need to figure out what the fourth one does
The rubber flex tubes (one to each front brake, one to front torque tube, one to rear torque tube) can squeeze shut from age. Once that happens the brakes still work but can be slow to release.Just took it for its first drive,the brakes seem to hang up.Im going to take it to work monday and look at it.Any ideas
