That would be great thanks.I'm chasing some stuff there on the 21st. If I win any of it, I'll be going to get it.
If I go, I can pick your top up and drop it at the freight terminal or store it in KS until you make arrangements.
I'm 500 miles away. Not going unless I win something.
Any advice on how to set that up if 98G doesn’t end up going?If it's on a pallet then LTL freight can pick it up from the govplanet location.
I can get you some quotes and set it up and send the item release and BOL over to the freight company for them to bring to the pickup.That would be great thanks.
Any idea what you think it would run to ltl from CO to NCI can get you some quotes and set it up and send the item release and BOL over to the freight company for them to bring to the pickup.
What are the pallet specs? Size and weight. Should be under the logistics section of the listing, your zip code and if it's a business or residenceAny idea what you think it would run to ltl from CO to NC
Shipping Dimensions | Length: 48”, Width: 48”, Height: 12” |
$378 to your residence
Shipping Dimensions Length: 48”, Width: 48”, Height: 12”
Doesn’t have a weight listed but I’d estimate 70-80 lbs
zipcode 27591 and is a residential
Thanks for the info on the freight.$378 to your residence
$285 to a terminal in Raleigh
