Pics of filter after WVO
rottiedog
New Bern, NC
I have been using Waste Veggie for the last year. Usually about a 50/50 mix. Changed the fuel filter about 6 months ago. This week, the truck lost all power. I replaced the filter and it is back to life. Took apart the old filter just to see the inside. Everything was pretty well saturated and clogged up. Still a fan of the veggie and think that a $20 filter is worth it when I have put 100 gallons of veggie in there. I just need to figure out a better dewatering system and a better filtering system.
1985 M1009
Lieutenant
58
Michigan
Is there a noticable difference in the way it runs between straight diesel and your 50/50 mix? If so, what are the differences?
rottiedog
New Bern, NC
I am not separating the glycerin but am planning on building a setup to do that. All I was doing was cooking in a water heater and letting it settle. Draining water and filtering down to 5 microns. Obviously, my method for dewatering and filtering is NOT working.
As for power, no noticable differences. I did run different ratios and anyything less than 50/50, I would have lots of trouble starting. I two tank system would most likely take care of that.
aboonski
West Melbourne Florida
I am curious to know what the 50/50 mix consists of? One person I met from Tennessee converted his truck to run on WVO and had a separate tank for straight WVO and a re-usable filter mounted on the engine that he could take apart and clean which he bought from an Ebay auction. I took pictures of his setup and the filter but must look through my photo files for them.
jag7720
Kansas City, MO
The only sure way to filter is with a centrifuge... http://www.simplecentrifuge.com
I have one of these and have filtered about 1000 gallons and have had no issues.
it is a bit of coin but you will get EVERYTHING out of the oil. At 1200 G's nothing escapes.
Also, never run wvo thru that filter. get yourself some valves and a separate tank and run straight WVO or straight diesel.
The wvo will react with the mild steel tank and polymerize... it will cause your sending unit to malfunction too.
aboonski
I have heard that you start the engine with diesel and switch over to WVO and visa-versa when shutting down. There's also something about a "return line" going to each separate fuel tank. How is that accomplished? I can just imagine having one fuel contaminating the other through one return line.
jag7720
Kansas City, MO
That is correct.
It happens the same way as the diesel. You just need two valves. One supply valve and one return... if you want, you can add a third valve for a controlled loop to keep the hot oil up front and less vacuum stress on the wvo filter
