Pics of Hood Locks?
yeager1
Colorado
LOTS of deuce security threads, but no pictures/ideas of hood locks. I was going to fab one up soon, but wanted to see others had done. My thought is: If you can lock your hood, imobilizng the vehicle is much easier and more secure, because as many have pointed out in the past- all the in-cab security measures people have done are fairly useless on a mechanical diesel if you can pop the hood and start it anyway.
Should be easy, but any ideas or pics?
yeager1
Colorado
Lock levers or things that move, don't lock your hood. Just as easy to go under the truck.
Since the motor will start with no accessory power, locking the on-off switch is fairly useless. Locking the engine stop is better, but again easy to get around if you can pop the hood. Yes someone could get under the truck, but would be much harder to get around security efforts (due to visability) from there.
lavarok
33
Fellsmere, FL
Speaking of deuce security, anyone ever install a fuel shutoff valve hidden out of plain view? Could be before or after the primary filter assembly.
dm22630
42
Front Royal, VA 22630
My feeling is....
If someone wants to steal it, they will. Its up to you to make it hard on them.
Personally, I like the emergency brake lock; battery disconnect switch; and the good old fashioned CHAIN through the steering wheel! :mrgreen:
2cents
1,806
A hidden valve of solenoid in the fuel system seems like a good way for frustrate a deuce thief as well as the more common battery discos and chains. Another thought I had was to make a 2 piece transfer case shifter and pin the pieces together. Drop it in neutral and away with the shifter. No foolproof way but each step is a step in the right direction. How about securing the right front valve stem to a fixed object? Drive away, tire go flat! Personally, I'd forget it!
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Once the hood is locked, then you have to worry about the side pannels. Where does it end? :wink:
bkwudzhom
ga
booby trapped needles that pop through the seat is an idea of mine--too bad i dont have a deuce to try it in
IHASFIP
TEXAS
Why not put a sleeve and a lock around the shaft on the clutch pedal so it cant be depressed? Then you cant jump start it.
Locks are only there to keep the honest people out.
This guy may be on to something. Take a piece of pipe and cut it in half. weld a hinge on one side and some sort of tab on the other. Then put one of those really hard to cut locks on it.
Heres what I think he was trying to say. :)
D
Sorry such a small pic...
JDToumanian
14
Phelan, CA
My anti-theft idea is to put a start button kill switch hidden up under the dash..... Unplug one of the connectors to the start button, plug it into a surplus toggle switch. Plug one end of a short jumper wire into the other side of the toggle switch and the other end of the jumper into the start button. This way, the start button will not work unless the toggle switch (which only you know the location of) has been flipped on.
Jon
jesusgatos
on the road - in CA right now
You guys are making it sound like he's overly paranoid, but I'm interested in figuring out how to lock my hood and every other part of mah deuce up too. I'm boing to be traveling in my M109 and leaving it unattended for long periods of time. Who knows where. My question is, what's a hood lock or any other reasonable theft preventative measure going to hurt? Of course, I'm assuming that these locks and other measures are not cumbersome to use.
gimpyrobb
27,785
748
Cincy Ohio
If you ever have a fire, it will be opened with an axe. I have seen firemen open hoods that were locked or jammed before. There is NOTHING you can do to prevent someone from doing what they want. Thats why I said make reasonable efforts to keep it from running (like locking the fuel cutoff rod) you should be good to go. I did like the clutch peddle lock idea too.
jesusgatos
My thought was that maybe the easiest and most effective hood lock would be door locks. It would be super-easy to rig-up a remote cable to somewhere inside the cab. I think that's the route I'm going to explore. Not real high on the priority list though...
yeager1
Colorado
I use my deuce for work, and often the cost of materials in the bed or on a trailer exceed the value of the truck by over 10 fold, that's what I am protecting.
A hood lock makes it harder and slower for even a skilled and determined thief to jump in at a stop and drive off with the cargo. If you don't like the idea- don't get one. For me, it's a cheap and effective way to make it harder (and louder!) for someone to steal my stuff. Keys in the cab are very easy to defeat because you know what, where and how to defeat it. If you can't find the problem or reason it won't start, it's tough. Keys are too much of a "smash here" sign. My plan is- Use a simple hidden cutoff (or whatever) combined with a locked hood; if it won’t start and you can’t pop the hood to find out why, that’s a great delay- and that’s all any security measure is- a delay.
