pics of m884
Bob H
160
Standard 318 leak
Front drive shaft removed requireing T-case to be in either High Lock or Low Lock
T-case linkage out of adjustment causing it to slip out of lock position, quick fix, tie it in place.
So did ya buy this thing or what?
Is the 24v generator still there on the drivers side of the engine?
Looks like most of the 24v stuff is still in place.
(24v only used for radio equipment)
As far as I know the M884 did not come with a tailgate ( I could be wrong tho)
1,808
Looking like someone made off with the 100A alternator from what I can see. Pity. Thanks for all the pics Joel. You didn't happen to take any pics of the sides of the truck did you? Like to get an overall view of it. Front drive shafts are still available NOS. I'm still game!
Elwenil
40
Covington, VA
The coolant leak is no big deal. Most of the time it is just the little curved bypass hose that needs replacement. Sometimes it is the thermostat housing or the heater hose leaking down and pooling on top of the timing chain cover.
m880 unimog
10
england
that looks like a new truck compared with the rotten lumps i am dealing with here.but they rise again!
my M884 came with a tailgate,but i can see most are set up for the shelter.mine came from USAF-
so the 24v alternators are rare then ?
maddawg308
762
Appomattox, VA
I've never seen a stencil put on the front bumper of the NSN of the vehicle, that's pretty interesting.
Nice looking truck, you have a good starting point...
