Picture of Towbar hooked up
TOBEXA
TIJUANA
WTF MAAAAAAAAAAAAAAAAAN these towbar's break your back to hook up and disconnect.........after my fist attempt at using a military towbar, here are my thoughts and questions.........it is not a simple process and if someone has a trick i would appreciate it...!where does the chain hook up to the towed vehicle? 140lb standard for a towbar?(or am i using an extra extra heavy one) not as simple as i hoped it would be....i
dilvoy
25
San Francisco, Ca.
Here is a picture of my tow bar after it's been hooked up. It is the best that I have seen so far. It is only 60 lbs. It fits the Humvee and CUCV shackles. It also allows for a one man installation because of the ability to realease the extension legs from their stowed position and if the towing vehicle is close enough, the lunette can be brought forward and easily placed onto the Pintal Hitch even if it is off to one side or the other. It also has an auto lock feature once the extension legs are fully extended. It's rated for use on the latest Up Armored Hunvee.
dilvoy
25
San Francisco, Ca.
That Tow Bar is made by IBISTEK and is sold to the general public. It is $1,530.00 plus shipping. This is the latest type with the extension legs that auto lock once they are fully extended.
