Pieces and parts for IP rebuild
DaneGer21
1,162
Creston, Ohio
What other pieces and parts would be needed or be wise to replace when tearing apart the IP to replace gaskets? I already have the “basic” gasket kit, and the HH orings on hand.
I was hoping maybe someone who’s been through a rebuild could offer some advice on what might need replaced, or what I should just go ahead and replace.
As of now, the only reason I wanna start this process is because of leaky gaskets if a few spots. Otherwise this is a completely fine and operational IP.
Thanks.
williamh
638
SanDiego Ca.
Thanks.
I don’t think I’ve seen anyone rebuild the ip , usually it’s just replace the gaskets or replace what had failed. If your really adventurous you might replace the bearings or the springs on the advance. Other than that ?? I have like 5 spares , I had more but just took them apart for “ how does this work “ or to sell a part.
87cr250r
1,982
Rodeo, Ca
Generally, you want to do as little as possible. I have only done this on the Stanadyne DB2 but none of the adjustable parts of the pump have to be disturbed to replace all of the seals. Adjustable components can be removed as an assembly.
DaneGer21
1,162
Creston, Ohio
Awesome! Because the only real issues at this moment are leaky gaskets/seals. Mainly the IP body/housing.
DaneGer21
1,162
Creston, Ohio
The only “issues” are leaky gaskets/seals. Mainly the IP body/housing and that’s it. It is currently on a running truck, so it doesn’t seem to have any other issues that I’m aware of.
DaneGer21
1,162
Creston, Ohio
I was just hoping to find someone who’s been through one a few times that might say; “X” always needed replaced, or “Y” was always worn out. Kinda the common things I might find when digging in. I’m not looking for a “complete” rebuild, but if “X and Y” always needed replaced, then I’ll do that in conjunction with my gasket kit.
87cr250r
1,982
Rodeo, Ca
You can get seal kits from companies like Diamond Diesel. On the Stanadyne pumps it's the throttle shaft seal that goes bad but it's not much more work to do the rest. I don't know if this applies to your pump. The paint marks mean calibration points so don't loosen the painted screws.
If you need to replace anything else the cost to repair will exceed the value of the pump.
rustystud
2,815
Woodinville, Washington
If your just looking to "refresh" your pump then replacing the Hydraulic Head 'O'-rings is the first thing. Then I would remove the "booster pump and after cleaning it up replace the shaft seal. This seal keeps the fuel in the pump and not in the engine. I mention the replacement and the cleaning in my rebuild thread.
