PINZ AXLE BOOT
TACTICAL6
Newark, Ohio
I just got one of those split style axle boots off ebay. Any one have any tips to putting them on? Like what way do you orient the seam?
thanks
B3.3T
92
SW Ohio
Just install it so the seam is horizontal. Check the Pinz boards for more details if you need.
krick3tt
Denver, CO
pinz axle boot
The temporary split boot should be at 10:00 on the passenger side and 02:00 on the driver side. Seal the boot seams with superglue and bolt together. To make sure you get all the oil off it first, use brake cleaner. Give it 20 min to dry (go have a beer and a sandwich) and then slip it over the lip near the tranny. Helps if the axel is level, lift it with the jack if it is not sitting level. Put the all the clamps back on and go.
Check the real4x4forum.com and search the archives for instructions by Jim L.
710M
