Piston Rings
Johan1963
Minnesota
I just got some NOS piston rings. The top two rings are identical. The top two rings have a beveled edge on the inside of the ring. There are no marks to indicate correct placement and the instructions don't cover it. My question is, if the top two rings are identical, which way does the inside beveled edge go? I read one post that said if the top tings were not marked, to place the top ring with the beveled edge facing up and the second ring facing down. I'd like someone to chime in and let me know. I called the company, but haven't heard from them.
John
87cr250r
1,988
Rodeo, Ca
For piston rings in general, it appears that the bevel should be on the top unless the ring has a tapered face.
