Please check my logic
Atchuuu
58
MS
I purchased a 100 amp kill switch from a boat place. After reading SS posts I’m thinking this is not robust enough and I need. 200 amp kill switch.
I plan to run a 24v to 12v converter off the ignition accessory switch using a 24v 50 amp relay. The converter is a 70 amp and will run a stereo, cab 4 speakers, phone charger and small amp.
My understanding is that the relay will allow the 24v ignition switch to provide the proper voltage to the converter without damaging the ignition.
Am I headed in the right direction? Any suggestions on the brand/type of relay? Do I need to add a diode to prevent back feeding the switch.
Last, I changed all glow plugs and was getting a blinking wait light. Truck was starting fine. Then it got cold and would not start. With new plugs installed I’m thinking it must be the ESS that needs replacing?
Mogman
9,217
Papalote, TX
After you check the glow plugs put a volt meter on one and see what is happening.
Also disconnect your batteries for a while, sometimes that helps.
Low battery voltage could also be a problem, make sure they have a fresh charge and are in good condition.
Atchuuu
58
MS
Batteries are fully charged and new. Truck starts right up when temp is warm.
Please explain what you men when you say “put a meter on one and see what is happening “.Are you suggesting something different than ohm checking?
Mogman
9,217
Papalote, TX
After you ohm all the glow plugs, should be very low ohms, pierce the wire on one of the glow plug wires with a volt meter, cycle the run switch and see what happens...
Coug
4,246
Olympia/WA
you're checking to see what voltage you have at the glow plugs, and how long they get that voltage, then what happens afterwards when you turn the start switch to "run"
