Goinmxn
- 0
- 6
- Amissville va
Thanks in large part to this forum here is the almost finished project from this summer. I have learned a lot and am willing to help anyone who needs advice if I can provide it! It has been a lot of work, but fun at the same time! I am mounting the sander on my second 5 ton now and should have it buttoned up in the next 2 weeks. This on uses a 6 yard gas over hydraulic spreader with all controls inside the cab. Dump trailer hydraulic lift pump is in the tool box for the plow, Mx7000 rotator/strobe bar on the roof, led tail turn and strobe lights on the back of the sander. The interior has air ride drivers seat, bluethooth Pioneer cd player, 2 12v plugs and a flip down dvd player all in a overhead center console with a led interior light (we get a lot of standby time with VDOT). All my 12 volt items are run with a battery isolator (like found in charter buses). All wiring is soldered and heat shrink protected outside and inside with redundant runs for backup. Still have a lot of little things to do, but most of the "hard" work is done. The second truck is getting a sander that is driven by a clutched hydraulic belt driven pump mounted on the passenger side of the motor. Other than that it will be identical. I could not be happier with how they are turning out, and if all goes well I should have a good winter!
