PLS wheels on M35A2
10NUGGET01
Oxford Alabama
I've found a set of 4 PLS wheels to put on my m35a2 bobber. Ill be running 1400s with the MRAP adapter plates. Before I purchase the wheels I was wondering if they will scrub/rub? Thanks in advance for any help. :confused::confused::3dAngus:
peashooter
205
Hanover, minnesota
They have the same 10 hole lug pattern as MRAPs dont they? The plate just has to mount to the front of the wheel face rather than the back to give it as much backspace as possible correct? I'm told 15" diameter is about the largest plate that will work with the existing rim flanged locknuts however.
