PM notification
cranetruck
75
Meadows of Dan, Virginia
Mike (mangus580), don't know if this is related to the new server or not, but I'm no longer notified of private messages received.
Also, the default display of posts show the oldest one first, can these things be modified by me, the user or do you have to make these changes?
Thanks,
mangus580
282
Western NY
There seems to be some intermittent email delivery problems. We are working to try to figure them out.
I finally fixed a code 'malfunction' that happened a while back. If when viewing the recent posts lists, you click on the topic name, it will take you to the begining. If you click on the little image just to the left of it, it should take you to the most recent post. This is how it worked for quite some time until I had done an upgrade. I just finally figured out where the problem was the other day and put it back the way it should be.
