- 285
- 144
- 43
- Colbert, GA
I decided to put together a spreadsheet of the various parts that everyone has been chattering about in the "Polaris MRZR-D4" thread, so I could keep it all in one space versus searching through what at this point is a 14-page thread. I'll try to keep it updated as we get more contributions regarding what works and doesn't work - big thanks to @publicenema from the great white north for helping search Polaris part numbers that are specific to the MRZR's. While what I have here is specifically for the diesel MRZR, I'm sure there may be some cross-compatibility with the gas models as well, I just don't know where.
Anything with a question mark(?) behind it is something that is unknown as I haven't been able to confirm a part number via Google or hasn't been verified to fit by one of us. If someone verifies that it does indeed fit, I'll remove the question mark.
If anyone has any parts that they've found worked for them - send me a chat and I'll be sure to add it to the list.
POLARIS MRZR-D4 PARTS LIST | |||
BODY/SUSPENSION | |||
POLARIS PART NUMBER | DESCRIPTION | ALTERNATIVE PART NUMBER | |
7044788 | Walker-Evans Front Shock | Walker-Evans #A-SH-922-32-637 | |
7044790 | Walker-Evans Rear Shock | Walker-Evans #A-SH-922-32-835 | |
4014042 | Throttle Pedal | Available on Amazon | |
DWT MOAPA Tires - 28x10x14 (Stock for Gasser) | DWT #UT-281 | ||
BFG Mud Terrain T/A KM3 28x10x14 (Stock for Diesel) | 86699331724 (Amazon) | ||
Floor Drain Plugs (x4) |
1333799 | Rear Axle | ||
5415700 | Shifter Boot |
ENGINE/TRANS/BRAKES | |||
Brake Fluid - DOT4 | |||
3040038 | Oil Filter | Napa 1083 | |
Oil - 15W40 - 3qts | |||
Polaris Demand Drive Fluid | Front Gear Case Oil - 8.5oz | ||
Polaris AGL Fluid | Transmission Fluid - 44oz | ||
7082178 | Air Filter | Napa 6489 | |
Batteries -
Battery Cutoff - Eaton's Bussmann 200A/48VDC | 187200P-03-1 | ||
2521460 | Fuel Filter | Donaldson P551099? | |
2521087 | Fuel/Water Separator | ||
2208933 (x2) | Front Brake Pads | Any for RZR900 Series? | |
2208936 (x2) | Rear Brake Pads | Any for RZR900 Series? | |
1911982 | Brake Master Cylinder | Quad Logic 100-1187-2 (Amazon) | |
3211225 | Drive Belt | ||
3235168 | Front Differential Cover | ||
1333792 | Front Differential (Complete) | ||
Clutch Cover Screws - M6x35 Fillister Head | Quad Logic B078RQBMR2 (set) (Amazon) | ||
1323443 | ASM Drive Clutch | ||
1323444 | ASM Driven Clutch | ||
3023106 | Alternator | ||
1023088-329? | Alternator Belt Cover (Original/Metal) | ||
1023899? | Alternator Belt Cover (Later/Plastic) | ||
3040406 | Turbo Assembly w/ Wastegate | ||
7082139 | Gear Selector/Shift Cable | ||
Starter | J&N Electric 410-24210 |
Accessory Items | ||
Hi-Lift Jack | Hi-Lift #UTV-424 | |
Hi-Lift Jack Mounts | Hi-Lift #TM-700 | |
2879493 | Half Windshield | |
L-Track (Cargo) Fittings | Check US Cargo Control website | |
Rear View Mirror (Mount Incorrect, but mirror is) | ISSYAUTO FVTMI019-FBA (Amazon) | |
Baja Designs Squadron Pro IR Light (Correct for MRZR) | Baja Designs Part 497073 | |
Blank 2-Position Light Switch | Marquardt # 3251.0058 |
Miscellaneous Tools | ||
1023846 | Drive Belt Changing Tool | Peatovie Mekar-001 (Amazon) |
