- 143
- 16
- 18
- knoxville tn
Been doing hub PM's and did not have a nice "soft" seal driver big enough for the hub axle seal. probably not the first to dream this up but --made this up out of PVC 3 in drain pipe. and you can make it long enough to easily drive the seal home with no risk of dents and can tap it in square on.
first pic is the complete "tool"
second is the inner ring to make the base thick enough (glue in)
last pic is a axle seal on the tool so you can see how it works (obvious as it is).
made install easy with no marring or 1000 popping half out and cocking when driving with a stick etc....
