Same thing happened here. This member asked a question then never left the group know the diagnosis. What gives? What was the problem? It is not helpful for me but would help others that may be experiencing the same issues. I think if you bring an issue to the group and the group helps you or try's to help you. In turn out of courtesy you share your findings to the group as to what was causing the issue that you ask help for. Also share the resolve or solution to the issue. Is that fair enough? Or should I just think Oh well. It is your problem?
