Positive camber on HMMWV 998 rear wheels ?
orgnal
Denver, CO
I finally got my 2 Man HMMWV 998 10 days ago and I have been working away on it as time permits. I noticed that the front wheels are quite perpendicular to the ground but the rear wheel have a very noticeable positive camber. Is this correct / common? Do I need to when them aligned properly? I did not notice any drive-ability issues when I took it for a spin around the neighborhood.
Thank you in advance
McReddy
bikeman
501
Ft. Bragg, NC
Yes, it's standard. It's so that when they get loaded up, as they 'should' they will move to a "normal" camber. If you drive around a military base, you'll notice it behind any unloaded unarmored HMMWV.
