Post beach trip maintanence
CanonNinja
Houston, Tx
Other than the typical wash everything 3 times with fresh water, what else do I need to check for? Hit some salt water crossing a "creek" about 2' deep, so soaking the truck right now with a pair of sprinklers under the truck and just finished soaking everything else I could get. Any seals I need to check on that are especially prone to salt water damage?
1,177
Where did you find a salt water creek (in Texas)?
M215
Spotsylvania, Virginia
Beach driving
I have always wanted to drive one of our deuces on the beach! NC outer banks are only 5-6 hrs away, Knots Island NC is even closer. As a kid / teen we used to drive on a beach in Ohio near Ashtabula called Walnut Beach on Lake Erie. The sand was hard packed and smooth. My first trip to NC outer banks / Hatteras Island on a fishing trip with a 4x4 was a real surprise. The sand was soft, deep and very difficult to drive on. Even with tire pressure reduced to 15 psi we still got stuck several times, the truck really stuggled on the beach (Chevy Colorado 4x4). Makes me think twice about taking 15K lbs. of green iron out there.
Karl
jasonjc
289
Gravette Ar.
RE: Beach driving
the -10 says to notify your supervisor to service vehicle as soon as possible.
but does not say what service to do. A lube job at leaset.
did you install the plug in the flywheel houseing??
The TM say that you can ford water but it also says not too unless you have too. And if you do take it to the shop.
SierraHotel
Haymarket, Virginia
RE: Beach driving
The North Carolina northern beaches (above Carolla) are much friendlier and less crowded. ‘Course getting up to them can be a chore. Oregon Inlet isn’t too bad, justr getting to the surf can be challenging, but its fine from there on out. I personally avoid Hatteras Point, its pretty fluffy there. But if you go to the inlet (down by the ferry), its pretty packed.
I’d worry about sand in the bearings as much as salt water. I usually have to replace mine in my suburban every other year. Sort of like sex on the beach, the sand gets into some of the strangest (and uncomfortable) places.
