Power brakes and Power Steering -- Need Help!!!
davemooney1
Vehicle Info: 1969 Kaiser Jeep M715, with a 6.9L diesel engine and T-19 transmission the rest is stock.
I have recently purchased a disc brake conversion from helitool (uglytruckling.com) and I was really wanting a power brakes setup. So does anyone know what kinda master cylinder will work, i am gonna prolly keep the rear brakes stock, but the front will be disc.
Also is there a power steering conversion for the m715?
Pics would be great also!
Any and All help is greatly appriciated!!
thanks,
Dave
email - davemooney1@hotmail.com
Elwenil
40
Covington, VA
Keep it simple and get the stuff from a J20 or J30 Jeep pickup. Better chance of getting stuff to bolt up. I'm putting the brakes system off of my '74 W200 dodge and it is definately not a bolt up deal. I'm going to have to do a little figuring to get the pushrod length right. Check over at www.m715zone.com It's been done many times in probably 1000 different ways.
sermis
17
Temple, TX
www.m715zone.com Lots of answers. Power steering, I used one from a 80's camero, works great, direct bolt up. Any of the GM, Jeep, ect that bolt to the inside of the frame, they are the same. Master cylender was from a 74 or 76 vet, can't find the post right now. I kept stock breaks so need same presure to both front and rear. With disk up front I think you could get a master from any truck or car that runs disk / drum and it would work. I also used a booster, will lock up braks if you stuff them.
Elwenil
40
Covington, VA
Heh, thanks Sermis, I didn't notice what the hell I typed for the The Zone's link, lol. That's what I get for messing around on SS at work...
sermis
17
Temple, TX
I think I use a newer chev booster off of a pickup and the corvette master. I would have used the pickup master too but it was for disk / drum and I need one for drum / drum. Too lazy to get and adjustable block and work out the presures. If you are going Disk / Drum most any will work. I have a buddy with a junk yard so I looked until I found a smaller booster that would not have clerance issues and used that. I also got a mount block from a Jeep Wageneer, goes between the booster and fire wall to help with mounting. Had to make a push rod from peddel to boostr and was done. Go over to the M715zone and ask. If it is 5/4 questions that is the place to ask.
oilcan
Ohio
If you don't have a good vacuum source on that diesel, go with a hydroboost setup off a chevy truck. Grab the p/s pump while you're there so you don't have to mod another pump for that extra fluid line you'll need.
