power contol box wiring issue need info asap!
jjohn360
gettysbur, pa
I have a m942. Apperently the pcb is supposed to prevent the starter from re-engaging when the truck is running. From what I have seen the wire that would be on pin F inside the box is not there on any of the pcbs. Pin F goes to wire 566 wich goes over to the altenator and I beleive that's what lets it know the truck is running. Is this a manufactuer fix? If so what is the reasoning behind removing the wire? If I wanted to replace the wire to make the stater lockout work what post on the soleniod would pin F connect to?
73m819
329
gainesville, ga.
Why do you need this info ASAP, is the starter starting on its own while the motor is already running or ????
