hedgehog69
- 2
- 18
- iowa city, ia
The control on my MEP-002A will not shut off the genset in the OFF position. Works fine in all other positions. Genset runs great. The little emergency pull out buttons will not shut it off either. Is the whole switch bad?
Also...thanks to Speddman, I believe. The 'quickflashing' tip. I think that is what it was called. I tried to find the post, but failed. The voltmeter..I think...was flatlined...nothing. I flipped the switch back to start after it was running...and bingo...works like it should!! Thanks!!!
