Power Steering noise and problem
Dave2018
73
Texas
Appreciate all replys. The power steering on my 1152A1 started making noise and not as smooth steering.
The truck is almost to 2000 miles total. I had fluid in my accumilator sight glass. Took off the top and it had fluid mostly full also.
Have not had any leaks or pump issues.
Getting my ducks lined up before just pulling parts...turbo trucks a pain sometimes.
Its really ramping up. Also my brakes are good on fluid.
Dave2018
73
Texas
I thought about bleeding the pump but have not found a plug. Looking.
m38inmaine
Maine USA
40 times lock to lock holding 5 seconds at each lock. You may also have a bleeder at the fan valve, that is the highest point in the system. I ended up replacing the PS pump with the same issue.
ikoinu
44
Los Angeles, CA
Just a thought, check the alternator bracket that the power steering pump is attached to (only if you have the smaller alternator).
I was having a problem with mine, bought a PS pump and found out the bracket had broken. Ended upgrading to a new 200 alternator, as I couldn't find the bracket for the smaller one.
Likely not your issue, but thought I'd put it out there.
Mogman
9,539
Papalote, TX
[B]ikoinu[/B] has a great point, you have not described the noise nor have you said if the belt was loose or tight, failing brackets/mounts for various components can cause noise and a loose belt which can effect the steering.
Bad or seizing idler pulleys can cause all kinds of symptoms
So is it a "buzzing" sound like air in the pump
Skip to around 1:07
Or is it rattling, squeaking, screaming like a Banshee??
Dave2018
73
Texas
Skip to around 1:07
Hello,
I should have put more. The belt is fine not squeeling. The alt brackets were tightened...Have not had any leaks. And the noise is a load pump noise.
Wanted to add that since this started when its making a lot of noise you can feel some vibration from the brakes. I will re bleed using tm guide. Hope its not my booster for the brakes. Can feel a little vibration on the booster where the low pressure leaves the booster pump on the brakes.
The tm says to turn engine off and then...??...to turn wheels fully to the left to start bleeding.
I think something may snap doing a full left turn of the steering wheel with no pressure.
Will update again.
Thx
Dave
Mogman
9,539
Papalote, TX
It is not likely the booster would give you pump noise and rough steering, me personally I would much rather replace a booster than a pump.
Have you replaced all the o rings in the high pressure hose fittings and all the return hoses?
If the system was working fine and not low on fluid and then started acting as if it had air in the system than I would look for a failure in the hoses/connections or a failed pump.
Dave2018
73
Texas
I agree on that. Fluid level was perfect though had some air mixing. Its possible it could be sucking up some air....
Will hit it again tomorrow.
Dave
Thunderbirds
364
Northern Black Hills South Dakota
Will update again.
Thx
Dave
Most important: Jack the truck's entire front end and put on jack stands. Then you don't have any resistance while turning...
Dave2018
73
Texas
Going to do that tonight. But wont be trying the full left turn with no pump pressure. Steering column may not be tuff enuff.
FlameRed
516
Florida
Hold on - you do NOT run the engine during this procedure! Make sure the pump is to the full mark. Turn stop to stop 40 times, stopping for a few seconds at both the right and left stops. Check the level once or twice during the procedure.
Don't get lazy and do less than 40 and don't rush and not pause for a couple of seconds at each stop as that is where the air bleeds out.
It should be very easy and should not make any weird noises as there is no load with it jacked up.
Dave2018
73
Texas
Yeppers... they did say to turn the engine off. I probably would have restarted it before the procedure. Thanks.
