Years ago, around15 now, while I was doing the plans for the M37 6X6 I decided that power steering was going to be a must. There had been info on reverse rotation steering boxes that matched the rotation of the stock M37s. I bought a pump to go on the 360 V8 I was putting in the truck and found a gear box unit from a mid 70s Dodge. Well this hunting season (September to November)trailering the 6X6 to three separate states for deer hunting and finally elk season here in Colorado was tough on the truck, I find some repair is in order. In New Mexico we took out three of the four motor mounts. The steering unit had been leaking slightly but now it has gone just about completely. The pump is now a steady drip from around the casing. A few years back on the earlier version of the G741 site there had been information about Chevy vans from the 80's that had reverse rotation units. Sure enough, they've got them. I pulled two from the local U Pull It yard and have kept one for a couple of years now while sending the other on to a fellow M person in Australia. I dug out the unit this weekend after pulling another pump at the local yard. I assumed the hose fittings would be standard inverted fllare, surprise, they aren't. They are some sort of 18mm x 1.5 fitting with a o-ring on the end. Nothing like a new challenge, so off to the internet I go. Lots of adapters to what is called AN, which looks very similar to the standard 45 degree flare, but I finally found where Weatherhead makes some adapters to 3/8 inverted flare fittings. They are 1445, 1446, and 1447. One site offering some outstanding information about adapting these newer units to older GMC motorhomes also mentioned cutting the metal tubes and using a compression coupling to join the old hose metal tube to the new unit metal tube. Apparently they are very close in diameter. Either method is promising so I don't have to run around looking for 70s 4x4 Dodges that are getting a little rare. All in all, the 40 bucks or so I had paid for a used unit and pump that ended up lasting 15 years through serious abuse is pretty satisfying
Regards,
Regards,
