power steering
1,172
Define best
DUECE-COUPE
Scurry. Tx
air o matic kit. they use air and are pretty simple to install. the alternative is a 5 ton power steering system. you have to trim this and install that and get the lines for it and build a resivior for the fluid. the air o matic used compress air fro m the system and a cylinder for assist. the air presure is directed through a modified drag link to the ia cylinder. the system uses a pressure relief valve to maintain air pressure for the brakes. if the air pressure drops below 65 psi, the valve shuts off so that the braking system has enough air pressure to operate the brakes.
jatonka
87
Ephratah, New York
Air-o-Matic air assist steering. Simple, Dependable. Arthur Bloom (631) 749 0100 tell him John Tennis sent you, might get you an extra 5 minutes worth of BS, or worse. JT out
