powered trailer... ?
tamangel
19
Nor Cal Coast
A while ago, I was looking at a history of Land Rovers and came across an article that talked about a trailer being powered from the power take-off on the rear of the LR's differential or axle housing via a short drive shaft connected to the trailers axle which contained a differential also.. Any applications to MV's like M715 or deuce?
Mike
rmgill
14
Decatur, Ga
Not really. You need the powered point RIGHT at the hitch swivel point. what you're talking about if I understand correctly is the Rubery Owen powered trailer for the 101" forward control land rover.
The challenge with such a system is that the trailer can exert a shove on the vehicle. The higher you put that point, the more likely, that at the wrong time, while off road it can shove the front vehicle over if it's slightly over balanced AND looses traction while the rear vehicle still has traction. Since the trailer is just about always on both wheels it's hard for it to loose traction and as such the chances of loosing traction on the front 4 wheels can make for some problems. The powered trailers for the 101" FC land rovers weren't put into any significant production as far as I know.
Here's a page showing this off.
http://www.allisons.org/ll/4/LandRover/FC101/
tamangel
19
Nor Cal Coast
The one I saw was a smaller trailer coupled with an old 'series' land rover..Not the Forward Control rigs..
Mike
same problems I suppose..
dc3coyote
19
Chattanooga TN
I belive there was a powered trailer for a Hemmtt on GL last month.
And to work out the drive shaft issue. I bet hydrolic drive. Lines going to a pump/drive wheels, then return to the rear PTO.
