army70deuce
- 3
- 18
- Anderson, SC
Has anyone used the Waterloo power steering system with the saginaw 710 steering box. If so have they also upgraded to super singles. I have had the powersteering for a long time and it works great. However, having just swapped to 395/85R20's with the MRAP adapter plates I now get tire rub against the pitman arm when turning right. Has anyone experienced this problem and if so what was the fix. I have tried shortening and lengthening the linkage that connects to the pitman arm and it gave me a slight increase before rubbing. I was going to try moving the entire setup back towards the axle to put it inside the turning radius of the tire but the hose from the pump is not long enough and that is a last resort because I'd have to remove, drill new holes and remount the entire setup. Any suggestions would be appreciated. Thanks.
It might be hard to tell from the pictures but the inside edge of the tread is what is rubbing against the pitman arm.
