russojap
- 0
- 16
- Knoxville TN
Hey guys I have to switch gears from mechanical to paint because of the weather. I intend to scrape off the loose peeling paint and then feather the edges in the best I can with an electric DA then put some rust oleum primer on the places. For the majority of areas where the CARC is still stuck I'm not sure what to do, I might rough it up a little, but it seems like it's rough enough for good adhesion as is. What can I do about hard to reach areas like hinges door handles, especially wheel lug nuts and things? I have used the black flex disc thing with a drill on the hood hinges with good success, but they are relatively flat. I've heard the rust converter won't hold paint. I am going to use the Behr latex for the job also. Thanks!
