I'm in the middle of a filter change and found something odd. I just got done doing a search and reading quite a few threads, with no answer to my question. First of all, my primary has a tall can that looks similar to the secondaries. I read in a coup;le threads how this can be good to allow more room for crud to accumulate on the bottom. I'm good with that. But what confused me is that there is no seal on the bottom of the filter!
Basically the empty can has 4 springs stacked up in it, then the filter sits on top of those. The springs hold the filter up against the housing. The problem is, the only way to ensure that the filter is actually filtering is for the bottom of the filter to be sealed so that the fuel has to go through the filter. Without any type of seal, the fuel just flows into the can, then up through the openings at the bottom of the filter and out of the filter housing.
This probably explains why the filter was very clean with very little in the bottom of the can.
Please tell me there is supposed to be something sealing the bottom...otherwise the primary filter does nothing!
Jim
Jim
